; *** START begin ***
G90
G21
M84 S0
G92 X0 Y0 Z0
; COMMAND_TOOL_MEASURE
M0 Attach ZProbe
G28 Z
G92 Z19.3
G0 Z40 F300
M400
M0 Detach ZProbe
; *** START end ***
Z probe stop
Z probe stop
Hi, sorry my French is very poor, in this gcode generated by Fusion360, I do not have button in my TFT28 to continue RUN after the M0, Am I missing something? Thanks in advance
Re: Z probe stop
Hi Manolocs,
I'm not sure to understand what you want... If you wanna create a probe button on the TFT, follow the tutorial https://www.makerfr.com/en/cnc/grbl-32- ... oi-du-tft/ "Create custom buttons"
Romain
(your topic has been moved in the international section)
Romain
Re: Z probe stop
Hi,
First of all thanks to Romain and the forum for a great project! I have just finished upgrading my RS-CNC to RS-CNC32 (thanks Romain for very fast delivery of the boards ). On the old setup we could not use M0 since this was not supported by Repetier. However on GRBL it is supported but on the ESP32 controller I have some issues. I want to pause a job from SD card using G-code M0 (to make a tool change during a running job). I can see that GRBL is paused correctly but the controller on the ESP32 board does not notice that and therefore a resume button is not shown in the information screen in the same way as if you have pushed the pause button. I have tried to look into the code to see if it could be implemented/fixed but currently without any luck.
Br.
Per
Br.
Per
Re: Z probe stop
Hi Manolocs,
As I had the same issue with M0 I have tried to dig in to the code for the GRBL controller on the ESP32 module. I have found a way to fix it so it now works (at least for me). Now it correctly shows the resume button when an M0 has caused GRBL to pause. It was only a few lines of code to change - hope that mstrens will fix this in his code tree as well (thanks to mstrens for making this amazing program available ). I have attached my changed file.
Re: Z probe stop
Thanks for your change.
I just updated the version on github with your change.
