Et donc ma réponse :Sailorpette a écrit :
This project has just been highlighted to me and look very similar in design and in name to that of Root CNC (versions known as R2 /R2.1 and the newly released R3 within our community) I do not see any references to my work I have done, either on the Root 2 Page or even the Root2.1 / 3 page? is this a mistake or an over slight? I can see you request attribution for any derived work based on your project, Please could you do the same for these two projects. Also it might be worth changing the name of your project to ensure people do not get mixed up between theses two.
Links to the relevant pages for attribution;
Root 2 (Original) = http://www.thingiverse.com/thing:1001437
Root 2.1 (Beta version number) Root 3 = http://www.thingiverse.com/thing:1750276
Regards Pete. PS the machine does look good.
Root 2 CNC multitool router 3D printed parts
by sailorpete
Root 3 CNC multitool router 3D printed parts
by sailorpete
Romaker a écrit :
Hello, I've known your CNC thanks to people who told me that my CNC was like yours. This was after I published my CNC. Linear guides using square tubes are not new as you can see:
https://www.youtube.com/watch?v=apwS68RLj7Q
https://buildyourcnc.com/s1m2.aspx
Should I put a link also to their work?
For the rest of the design, it's common sense, sorry if you find a resemblance, I did not inspire your work, without you this design would have been the same!
For the name "R-CNC", R is the first letter of my first name "Romain", do I change my first name too?
All my pieces have been drawn completely, nothing is the fruit of your work on my project.
Given all of these elements if I have to put links to your achievement, you have to put links to all CNCs that closely resemble your CNC, whether printed or not, that contain elements similar to your achievement. And if you ask me, I'll find you a lot.
It is a pity to lay charges based solely on the presumption, in public, without having contacted me privately before, especially for a project that brings me nothing financially.
But I'm flattered that you contact me, it means that my design is starting to be successful.
You can continue the discussion in public or in private if you want, it is you who see.
Note: I'll get you your V3 that I have not seen yet
Best regards Romain
