Using rs cnc
Using rs cnc
Having a small problem with the travel speeds using estlcam.if I leave them at the stock 60mms it bairly moves so I had to bump it up to 250mms which seems way to high but seems the only way to get it to move at a normal speed. Is there something in the firmware that I need to change so the movement speed is more accurate ?
Re: Using rs cnc
Travel speed is only managed by the CAM software (here Estlcam), not by the RS-CNC sofware.
In Estlcam: "CNC program generation" Tab ->"Values" Tab
In the "Rapid feed" box, i put 2400 (mm/min)
