Firmware 2.0.x vs 2.1.g
kulfon250wr
Message par kulfon250wr »
Hello
I have firmware version 2.0.x is it worth upgrading to version 2.1.g??
In my machine, it happens that when cutting for a long time (a lot of elements), the software hangs, the spindle stops or goes in the wrong direction. Can an upgrade help?
B/r
Maciej
Re: Firmware 2.0.x vs 2.1.g
Hi kulfon250wr,
Actually, we are at the version 2.1.jOTA (26 april 2023) for the TFT firmware. I invite you to update anyway.
The update will probably not solve your issue of motors going in the wrong way. For that, I suggest to check the DIR- wire connections of the concerned drivers. Check their connections between the drivers and the Grbl board. DIR- signal controls the way of rotation of the motors.
See ya,
kulfon250wr
Hello
Thx for answer, but
The problem is that the plotter cuts well for 40 minutes and suddenly goes stupid, it's not a connection problem, it's something in electronics or software that causes it
kulfon250wr
Problem with Firmware in Arduino..
rominetb44
Message par rominetb44 »
Hi,
Which OS are you using ?
Which version of Arduino are U using ?
What is the size of your TFT ?
Regards,
kulfon250wr
Arduino 2.1.0
MacOs Ventura 13.4
TFT 3,2"
Board 1.0-1.5
rominetb44
Hi,
I think it is an issue of Arduino 2.1.0 or MacOs (I'll try tomorrow).
You should better use Arduino 1.8.19.
However, I fix the issue changing the name of the files.
You could try it : https://github.com/rominetb44/grbl_cont ... master.zip
Let's me know if it's ok.
See u
kulfon250wr
The same situation, tomorrow i try Arduino 1.8.19
rominetb44
I think it is due to bracket....
Let me know with Arduino 1.8.19. Otherwise, I will change the name of this files.
see U
rominetb44
rominetb44 a écrit : 04 mai 2023 21:35 I think it is due to bracket....
see U
In fact, these files are no longer used...
You can dowload again the firmware :
See U.
