Mk4duo+tft32+makerfr i3rs
Re: Mk4duo+tft32+makerfr i3rs
I printed the proof cover to mount the ignition control, the print is male because of the damaged probe, but the correct measurements for the assembly
A tutorial for editing the Nextion screen is planned, and a small video is possible to see the different screens.
Thanks in advance.
Thanks in advance.
I'm interested to see this when you have time to do it - thanks
Lebress a écrit : 30 juil. 2019 08:34 Hello,
Thanks in advance.
no at the moment no tutorial is a modification I am experiencing, if you are interested I will explain how to do it
sure, i'm proud to mount, as soon as i'm complete i'll make you a video
https://1drv.ms/v/s!AnbhzYLZ2RdfgbZGF_uEDH4UCroj_A
Thank you,
Yes, I am interested in your modification and your help will be welcome. So if you can explain to me your modification and the equipment to buy would be fine.
Lebress a écrit : 31 juil. 2019 11:41 Thank you,
then as components I bought
- nextion 4.3
- and 1 Micro SD Card module (as the standard microsd is only for updating the firmware)
as software I changed from marlin to mk4duo which allows me to manage the makerbase 1.6 much more simply
for the connections I used pins 16 and 17 for the nextion
for the sd module I used the pins
50, 51,52,53
this is fast information, as soon as I have time I put all the changes into detail
- Terrible45
Nice job and video.
