My R-CNC is skipping steps
Re: My R-CNC is skipping steps
ok, reset button for 0 .....
Modifié en dernier par GIANNI le 03 nov. 2018 17:50, modifié 1 fois.
so, after loading the firmware repetier I did some tests ... unfortunately the problem still persists ...
16 mm mdf, every time the drill drops 1 mm it creates a step to the left on the x axis!
I do not know what to do anymore ... I do not think it's a mechanical problem, the step that's created is too regular ....
Try to invert your TB6600 (X <-> Y) to see if it's not a problem with one of these.
Try to see if when you move your Z with the screen, the X is moving too.
Try to test another gcode.
great !! I inverted the TB6600 and the problem has passed from the x axis to the y axis !!!
so is the component defective? If I replace it with a new one the problem should disappear ... I think
it must be defective.
thanks for the support.
Nice troubleshooting !
