Questions about MKS 1.4 & 100K Resistor
3DStyle
Message par 3DStyle »
Hi guys,
I made a terrible mistake and burnt my Arduino Mega 2560 and RAMPS 1.4 boards on the R-CNC.
Don't have the time to wait for the new boards I bought from Aliexpress. I have laying around a
MKS Gen 1.4 board which I want to use until I'll receive the boards that I ordered.
1. Is that okay to use the MKS Gen 1.4 with the R-CNC?
2. What is the use of the 100K resistor in the R-CNC? Do you have an idea where I should connect it to on the MKS Gen 1.4 board?
I'll appreciate any kind of help!
Thanks.
Re: Questions about MKS 1.4 & 100K Resistor
Hi 3Dstyle !
You can not use this board instead Ramps besause on the MKS 1.4 the drivers are integrated and you can not plug "step" and "dir" wires :|
3DStyle
Hi RoMaker, thanks for your answer!
My bad, I have the MKS Gen v1.4, which does have ports for external motor drivers.
I have this one:
I just wonder where should I connect the 100K resistor in this board, and what is the purpose of it?
Thanks!
Aze
Message par Aze »
Hi,
you plug it to the E0 thermistor. It's just because there's a thermal control in the firmware (it's for 3D printers: if there is no thermal resistor, the firmware stops). In fact you can desactivate this somewhere in the firmware, but you have to search on google, I can't help you (and it's faster to just plug a resistor).
3DStyle
Thank you very much Aze!
So basically the 100K resistor pretends to be a "heated nozzle", correct?
Kachidoki
Message par Kachidoki »
I checked quickly into the Repetier code, it seems that replacing:
Code : Tout sélectionner
#define EXT0_TEMPSENSOR_TYPE 1
by:
#define EXT0_TEMPSENSOR_TYPE 0
should disable the thermistor and assume a fixed temperature of 25°C.
I have not tested myself but if it can help. ;)
Aze
Message par Aze »
3DStyle a écrit : 21 août 2018 18:32 So basically the 100K resistor pretends to be a "heated nozzle", correct?
It pretends to be a thermal resistor :P but yes, it's a bit like a "heated nozzle" if you want. The firmware just check if there is a value on the thermistor (100kohm, 2ohm, 100000kohm, everything but not infinity) otherwise it means than the thermal resistor is broken (it's a brittle component) and your house could burn :o
3DStyle
Thanks guys, it works great! :)
