file transfer, transfert des fichiers
le_berger_de_photons
Message par le_berger_de_photons »
how can I either send a file to the sd-card from my pc via the usb cable or run a file from my p.c. without passing by the sd-card?
je cherches a pouvoir soit envoyer des fichiers de mon p.c. windows par le cable usb vers le rs cnc ou controller le rs cnc directement depuis mon p.c. windows. est-ce possible?
merci et/and thank you
Re: file transfer, transfert des fichiers
Hi le_berger_de_photons,
To answer to your questions, can you please confirme which version od the Grbl board kit you are using: v.1.0 or 1.5, or 2.0 ?
Thank you,
See ya,
P.S. : You also have the right to begin your posts by "Hello" or "Hi".
Hello HTheatre!
I only just now see that you responded to me that day. I'm not sure why I didn't receive a notification. I guess I didn't tell the system to notify me.
As I said in the other post I just wrote, thanks you so much. I wonder when you did the post I followed and replied to, but I'm not yet clever at navigating this resource. I guess I'll know in a minute, but wanted to thank you for responding so fast in September thought I didn't know.
le_berger_des_photons
