A1.Hard limit reached(P?)
- kulfon250wr
1. I don't have limit switches!!!
2. The problem occurs in 90% of cases, in long cuts, here, as you can see in the photo, he did over 83% and suddenly boom.
3. Electronics connected correctly, working for several years, nothing overheats.
What could it be?
What could it be?
- rominetb44
Re: A1.Hard limit reached(P?)
Hello kulfon250wr,
If you don't have limit switches, you can try to disabled it with the command $21=0 (you will not be able to run homing anymore).
See U
See U
- kulfon250wr
Today was even more interesting. I cut about 47%, did Pause. After about 2 minutes of Pause, this error popped up. It's starting to piss me off because it's making my job a lot harder. Does anyone have an idea what it is or is the only way to change the controls?? I wouldn't really want to because I liked it...
- kulfon250wr
""If you don't have limit switches, you can try to disabled it with the command $21=0 (you will not be able to run homing anymore).""
How should I do it from the GRBL console, or add to the commands in the cut file, if so, where at the beginning?
I don't use basing
I don't use basing
- rominetb44
Hi,
You can do it by connecting a PC to the screen board. But if you are no friendly with it, it is not a piece of cake...
If you are not using limit switch, did you have connected something (wire) on the end stop pin ?
See u
See u
- kulfon250wr
I didn't connect anything to the pins
- rominetb44
You have to use jumper.
- kulfon250wr
Thx I'll try. I also made a new, heavily shielded MB > TFT cableYou have to use jumper.
- rominetb44
It is a very good idea.kulfon250wr a écrit : ↑09 mai 2023 23:26Thx I'll try. I also made a new, heavily shielded MB > TFT cableYou have to use jumper.
With ma own, I was using an usb wire which is very suitable for this.
