Firmware 2.0.x vs 2.1.g
- kulfon250wr
Hello
I have firmware version 2.0.x is it worth upgrading to version 2.1.g??
In my machine, it happens that when cutting for a long time (a lot of elements), the software hangs, the spindle stops or goes in the wrong direction. Can an upgrade help?
B/r
Maciej
B/r
Maciej
Re: Firmware 2.0.x vs 2.1.g
Hi kulfon250wr,
Actually, we are at the version 2.1.jOTA (26 april 2023) for the TFT firmware. I invite you to update anyway.
The update will probably not solve your issue of motors going in the wrong way. For that, I suggest to check the DIR- wire connections of the concerned drivers. Check their connections between the drivers and the Grbl board. DIR- signal controls the way of rotation of the motors.
See ya,
See ya,
- kulfon250wr
Hello
Thx for answer, but
The problem is that the plotter cuts well for 40 minutes and suddenly goes stupid, it's not a connection problem, it's something in electronics or software that causes it
Thx for answer, but
- kulfon250wr
Problem with Firmware in Arduino..
- rominetb44
Hi,
Which OS are you using ?
Which version of Arduino are U using ?
What is the size of your TFT ?
Regards,
Regards,
- kulfon250wr
Arduino 2.1.0
MacOs Ventura 13.4
TFT 3,2"
Board 1.0-1.5
MacOs Ventura 13.4
TFT 3,2"
Board 1.0-1.5
- rominetb44
Hi,
I think it is an issue of Arduino 2.1.0 or MacOs (I'll try tomorrow).
You should better use Arduino 1.8.19.
However, I fix the issue changing the name of the files.
You could try it : https://github.com/rominetb44/grbl_cont ... master.zip
Let's me know if it's ok.
See u
See u
- kulfon250wr
The same situation, tomorrow i try Arduino 1.8.19
- rominetb44
I think it is due to bracket....
Let me know with Arduino 1.8.19. Otherwise, I will change the name of this files.
see U
see U
- rominetb44
In fact, these files are no longer used...rominetb44 a écrit : ↑04 mai 2023 21:35 I think it is due to bracket....
see U
You can dowload again the firmware :
See U.
