axis offsets
Posté : 14 juin 2021 10:32
par franmoreno
Hello, I'm looking in the forum for a problem like mine and I can't find it, some axis moves and I can't find the reason, saying that the engines after 10 minutes of work I can't touch them because of how hot they get. any lighting? greetings nema 23 2.8a engines configured in the drivers with their power
Re: axis offsets
Posté : 14 juin 2021 15:29
par franmoreno
here you can better appreciate the displacements
Re: axis offsets
Posté : 18 juin 2021 03:34
par DaveDolsonUSA
If you own a dial indicator, I’d consider putting a known straight sided block and lay it out and tram your machine. By running the dial indicator in y then x axis if you got a movement problem that will help find it, check you tube videos for more info.
Based on your findings it may suggest an axis binding. Could be a belt tension condition.
Or a bearing to tight or clogged with chips dirt etc.
You may find a belt issue, (I actually own a mechanics stethoscope that I can listen to noise conditions. I used it in my 3dprinter with good success.) , by listening to each axis run the full distance. Make a small adjustment to belt tension like a in either direction 1/4 turn no more, and listen for the motor straining more or more belt pulley area vibrations. If the belt is to stretched the teeth will not align properly and make a noise and vibration.
If you own a clamp on DC amp meter you can find a possible binding condition making a larger amp draw for a motor. The smoother the machine moves the less current is needed for movements and cool motors.
The more current equals motor over heating and poor and possible dangerous use.
Does this happen when using different. Xy locations?
Post your findings…
Re: axis offsets
Posté : 27 juin 2021 04:55
par franmoreno
After many tests I begin to see the light, the acceleration of the X axis I have it in 400, on the other hand in the Y axis I have had to lower it to 35, I do not know if this hurts something but it is the only way that I do not know move the Y axis.
Greetings
Re: axis offsets
Posté : 28 juin 2021 10:20
par franmoreno
can someone tell me why the acceleration is so low if it is normal and how could I fix it? If I put the independent Y axis driver with another transformer, could it be solved? Thank you
Re: axis offsets
Posté : 28 juin 2021 17:13
par jahislove
did you activate the laser mode in GRBL instead of CNC mode ?
it's parameter 32
$32=0 for CNC
$32=1 for Laser
type this in the serial consol , or add button in the LCD
Re: axis offsets
Posté : 29 juin 2021 10:12
par franmoreno
This is how I have it put, on the other hand when I cut a circle or a square the Y axis does not move, I am investigating why it moves when it is something more complex than a square or a circle. Greetings
