Z axis problem
kulfon250
Z axis problem
Message par kulfon250 »
I have 3 identical motors, when I move the X and Y axis it moves by the correct dimension which is shown on the LCD.
When I move the Z axis, 3mm of the movement is 6mm on the lcd, where's the problem?
As a result, I cannot set the Z cut level
B/r
Maciej
DevCad, DevWing, DevFuse, RS-CNC32 with laser, Prusa i3 MK3 and more :)
Re: Z axis problem
Hi Maciej,
Was the first time you started your RS-CNC32?
Please, post a picture of the table printed on your drivers and another one of the microswitches' config of the Z-axis' driver.
See ya,
kulfon250
Re: Z axis problem
Thx for help.
I found the cause of the problem, for some reason, despite 3 identical motors.
I had to make different settings for the Z axis motor in TB6600.
Re: Z axis problem
Hi Maciej,
kulfon250 a écrit : 13 juin 2021 23:45 I had to make different settings for the Z axis motor in TB6600.
Exactly ! That's why I had asked you to post pictures of the Z-driver.
I am glad to read all woring fine for you now.
See ya,
