Hi all,franmoreno a écrit : ↑14 mai 2021 18:37 I followed your steps but the laser did not react, I rewired the entire board to see if the fault was there but the laser was still the same. in the end I read a lot on the forum and decided to put a resistance between the S and 5v and I was happy to see that the laser was working correctly. now to enjoy , thank you from the heart
I experienced exactly the same problem after installing the laser. Also solved it with a resistance! So thanks for the hint! It had already cost me a few days mucking about with settings.
But now rises the following question: Which resistance is the optimal solution? I tried 4 types that I had lying around, and only one worked, but does it function to it's maximum potential now? I couldn't identify the value of the resistance I used due to colorblindness
What type of resistance have others used?
BR, Bas
