Velocity Work
Velocity Work
hi, after many headaches the machine walks .. I would like to know if someone can help me to know how to slow down or increase the speed while the machine is working. Greetings
Re: Velocity World
There are 2 types of speed depending on the type of move.
In the Gcode, you have e.g. G00 and G01.
G00 means that you do not mill but just move. You can't define the speed in the Gcode because the speed is fixed (per axis). To change this value, you have to edit the GRBL parameters. More here: https://github.com/gnea/grbl/wiki/Grbl- ... figuration (see $110/$112).
G01 is used when you mill. The feed rate MUST be specified or in the command or before. The speed is usually given in mm/min (or inch/min) just after the letter "F" (for feedrate). The value that you give remains valid for following G01 commands (unless you specify a new F value).
