Hi,
I use my RS-CNC32 to do laser jobs, but I find them to take very long. Even if I set the speed on Lightburn/LaserGRBL to high values, the machine still engrave pretty slow. I'm trying to understand where is the "bottleneck". Do I need to change the TB6600 drivers settings to get more speed, or is there any limitation to the electronics that cause the low engraving speeds?
Thanks
Increasing Laser Engraving Speed
Re: Increasing Laser Engraving Speed
did you check the grbl parameters about max speed and max acceleration?
Send the command "$$" and look at the parameters.
More here:
https://github.com/gnea/grbl/wiki/Grbl- ... l-settings
More here:
