very noisy stepper motor ? - solution
stu_le_brew46
Message par stu_le_brew46 »
I have a problem with a very noisy stepper motor, specifically the Y axis stepper.
The cutting results are 100% fine now and very accurate, so the motor is working fine. When I remove the belt the motor turns freely and the X axis gantry also moves freely, the noise sounds like a mechanical grating.
I plan to try a different power controller later in the week
wondered is anyone else has experienced a noisy stepper ???
S
Modifié en dernier par stu_le_brew46 le 19 janv. 2021 14:16, modifié 2 fois.
jijiz
Re: very noisy stepper motor ?
Message par jijiz »
stu_le_brew46 a écrit : 29 déc. 2020 19:32 I have a problem with a very noisy stepper motor, specifically the Y axis stepper.
S
Is the noise only happens with the belt mounted ?
I had this issue when the belt where too much tighten.
stu_le_brew46
Re: very noisy stepper motor ? - solution
I think the problem is OK now, when the stepper is removed from the machine, there seems to be no real noise at all, so my conclusion is that the aluminum frame is acting to amplify the noise/vibration.
So I have redesigned the Y stepper mount to be stronger and hope this reduces the vibration
hiphouser
Message par hiphouser »
Dm542T from stepperonline is the solution!
Mes imprimantes 3D:
Ender 3 Pro
Voron 2.4 (350X350mm)
...I3RS32 en cours...
RS-CNC 32 finie! (1mX1m)
