Z-Axis gone crazy
Remo400
Z-Axis gone crazy
Message par Remo400 »
since yesterday my Z axis of the I3-r behaves very strange.
Whenever i want ot zero it it only moves upwards never down.
When i turn the spindels down by hand so the sensor turns on but as soon as i click on "home Z" in the Repetier host it first moves up a bit stops shortly and the continues up another 3 cm an stops.
The same happens withe PC disconnected and use the "auto home" form the printer panel.
I already repalced the Motor Driver but no change.
I deleted the Arduino and reflashed it from scrach - no change.
I disconnected and reconnected all cables on the Ramps Board to make sure no bad or loose contact - no change.
All other motors and funcitions work.
Can the Arduino itself have such a fault? Or the Ramps 1.4 Board?
Any advice welcome
Cheers Erwin
