finally everything is working like it should. Thanks for all the help here.
next step is the configuration of the cnc.
do i have to enable soft limit or hard limit? I have only on one end Endswitches.
and what are the best values for
$110, $111, $112 and $120, $121, $122 and the other params. Is there perhaps a list of good values what are working best? i use nema23 motors with around 3Nm
Georg
max speed on the axis
Retourner vers « GRBL32bits V1.0/1.5 »
Aller à
- ↳ Imprimante 3D "I3 RS"
- ↳ Mécanique I3 RS
- ↳ Câblage I3 RS
- ↳ Réglages I3 RS
- ↳ Imprimante 3D "I3-R"
- ↳ Mécanique I3-R
- ↳ Electronique de la "I3-R"
- ↳ Réglages et paramètres de la I3-R
- ↳ R-CNC
- ↳ Montage R-CNC
- ↳ Electronique R-CNC
- ↳ Réglages R-CNC
- ↳ Câblage RS-CNC (pas 32bits)
- ↳ Software RS-CNC (pas 32bits)
- ↳ Mécanique RS-CNC32
- ↳ Mécanique RS-CNC / RS-CNC32
- ↳ Câblage
- ↳ Réglages/flashage/utilisation
- ↳ Questions générales CNC
- ↳ Fraises et réglages usinages
- ↳ Logiciels CAO ET CAM
- ↳ Vos réalisations
- ↳ Vos imprimantes 3D
- ↳ Vos fraiseuses CNC
- ↳ Divers
- ↳ Vos objet imprimés et fraisés
- ↳ Présentations
- ↳ Bistro
- ↳ GRBL32bits V1.0/1.5
- ↳ I3 RS 3D printer
- ↳ R-CNC
- ↳ R-CNC Assembly
- ↳ R-CNC electronic
- ↳ R-CNC Adjustments
- ↳ I3-R 3D printer
- ↳ I3-R assembly
- ↳ I3-R Wiring
- ↳ I3-R Software
