Questions about M6 command (Manual Tool Change)
3DStyle
Message par 3DStyle »
Hi,
I'm trying to run a G-Code file that has a M6 command (manual tool change) in it and I get some odd results.
1. Every file that has the M6 command in it, the LCD screen shows an error: "20. Unsupported command". Why is this?
This command is supported on GRBL by nature - https://github.com/vlachoudis/bCNC/wiki/Tool-Change
2. The M6 is not usable with the LCD interface menu. When the machine stops after the M6 command, basically the machine is stuck, I can't resume the job afterwards.
In addition, can we have control on the gantry after the tool change, in order to zero the Z axis after we changed to new tool?
Or, is there any other approach for changing tools during a milling job?
Re: Questions about M6 command (Manual Tool Change)
As far I know, GRBL does not support change tool.
So if you put it in a Gcode file that you send from the SDcard, GRBL will generates an error and stop.
bCNC has develop a workaround.
Before sending the gcode file to GRBL it (internally) modifies the code being sent.
It offers 3 options:
- send the code as it is. In this case GRBL will get the change tool command and generates an error
- discard the tool change command. In this case, there is a risk that the CNC does not operates as expected
- use a macro in order to simulate the tool change.
This requires some setup in bCNC.
The easiest (from my point of view) is still to generate a different gcode file for each tool.
Furthermore, if you install a fix probing system, the TFT offers you some options to manage the change tool in an easy way (but still with one file per tool).
3DStyle
Hi mstrens, thanks for the informative answer.
Can you please elaborate about the TFT options to manage tool change with a fixed probe system? What is the procedure?
