I bought a new kit of the RS-CNC-32Bit, and when I connect a SD card to the LCD the screen shuts OFF.
I tried with 3 different TFT LCDs and they all shows the same result. I have SdFat 1.0.0 installed. Tried different SD cards - same issue.
Does anyone know what could be the root cause for this?
LCD Turns OFF When Inserting a SD Card
Re: LCD Turns OFF When Inserting a SD Card
my first thought on your problem would be that the power connection is a problem.
Do the other functions of the LCD work - like home the machine for example ?
To see if this is the case I would suggest to try with a USB cable connected to a PC/Laptop plugged in to the front panel as this will supply power to the electronics.
