Hi,
where can i set the homing speed. Now the Z axis is homing fine but the X and Y is very slow.
Thanks for advice.
PS
I've upgraded from rs-cnc to rs-cnc32. On RS-CNC the homing speed was ok
Homing speed
Re: Homing speed
Try this settings (=improving accelerations, speed and let the motor always enable if one day you want to change your tool with different gcodes):
$120=400
$121=400
$110=10800
$111=10800
$1=255
Enable the soft limits, too:
$20=1
and put the size of your working space there:
$130=
$131=
$132=
You just need to create a xxxx.nc file on your SD card with these parameters and run it like a normal gcode. Turn off and on your CNC and you've got a new beast CNC.
$120=400
$121=400
$110=10800
$111=10800
$1=255
$20=1
$130=
$131=
$132=
Re: Homing speed
Thank will try next week
Re: Homing speed
Works perfectly.
Thanks
Thanks
