Hello all,
I just starting up my new build cnc. Everything works exept the x as motor.
When I press the move + or - the motor runs very slow.
The numbers of the coordinates on the screen are chanching qiucker than that the x dolly is moving.
I hope some one can help me to solve this
Greetings Jeroen
x motor is running bad
Re: x motor is running bad
Hello
Can you connect the x motor on the y driver and the y motor on the x driver to see that the problem is the motor or the driver?
Problem fixed
Bad wiring
Bad wiring
