With the electronics and power supply being mounter under the main cutting board, which has a bunch of holes in it, won't dust be a problem - or even fire hazard?
i'm especially concerned about the power supply which even has a fan on it, which inevitably will suck dust in.
Dust protection of electronics - fire hazard?
- loadinglevelone
Re: Dust protection of electronics - fire hazard?
https://www.makerfr.com/forum/viewtopic ... 707#p29707
Toute l’électronique sous la CNC, ça ne craint pas un peu en terme de vibrations / poussière / erreur de manip / fuite lubrifiant si on veut en mettre un peu ? Déporter dans un "petit boîtier" à coté ? ou mettre une planche intermédiaire pour assurer un peu d'étanchéité ? Bonne idée ou pas ?
All the electronics under the CNC, doesn't it suck a bit in terms of vibrations / dust / handling error / lubricant leak if you want to put in a little? Deport in a "small box" next door? or put an intermediate board to ensure a little waterproofing? Good idea or not ?
