Câble de liaison carte GRBL 32bits <<>> carte adaptateur GRBL TFT
coyo5050
Re: Câble de liaison carte GRBL 32bits <<>> carte adaptateur GRBL TFT
Message par coyo5050 »
Just so I understand this correctly, the shielding in the pictures / diagrams is the shielding that is already part of the cable? You are just cutting the wire to put in the dupont connector but continuing with the shielding in the cable to whatever length you need?
Hi coyo5050,
coyo5050 a écrit : 23 juil. 2020 02:44 Just so I understand this correctly, the shielding in the pictures / diagrams is the shielding that is already part of the cable? You are just cutting the wire to put in the dupont connector but continuing with the shielding in the cable to whatever length you need?
Exactly ! You all understood.
See ya
