Hi,
I finally finished the construction of the RS-CNC (mechanical part).
Now, I need to choose the motors and hardware, the recommended motors are nema 23 1.23 N m, I would use powerfull motors 3 N m nema 23 or 2 N m CLOSED LOOP nema 23. What do you think about that?
Should I pay attention to something in particular? size? weight?
What is the best motor?
Retourner vers « GRBL32bits V1.0/1.5 »
Aller à
- ↳ Imprimante 3D "I3 RS"
- ↳ Mécanique I3 RS
- ↳ Câblage I3 RS
- ↳ Réglages I3 RS
- ↳ Imprimante 3D "I3-R"
- ↳ Mécanique I3-R
- ↳ Electronique de la "I3-R"
- ↳ Réglages et paramètres de la I3-R
- ↳ R-CNC
- ↳ Montage R-CNC
- ↳ Electronique R-CNC
- ↳ Réglages R-CNC
- ↳ Câblage RS-CNC (pas 32bits)
- ↳ Software RS-CNC (pas 32bits)
- ↳ Mécanique RS-CNC32
- ↳ Mécanique RS-CNC / RS-CNC32
- ↳ Câblage
- ↳ Réglages/flashage/utilisation
- ↳ Questions générales CNC
- ↳ Fraises et réglages usinages
- ↳ Logiciels CAO ET CAM
- ↳ Vos réalisations
- ↳ Vos imprimantes 3D
- ↳ Vos fraiseuses CNC
- ↳ Divers
- ↳ Vos objet imprimés et fraisés
- ↳ Présentations
- ↳ Bistro
- ↳ GRBL32bits V1.0/1.5
- ↳ I3 RS 3D printer
- ↳ R-CNC
- ↳ R-CNC Assembly
- ↳ R-CNC electronic
- ↳ R-CNC Adjustments
- ↳ I3-R 3D printer
- ↳ I3-R assembly
- ↳ I3-R Wiring
- ↳ I3-R Software
