guys, I ask you for help, I can't connect my rs cnc to universal gcode sander.
I connect the cnc usb to the pc I turn on the cnc and open the program, connect with the com port to baud 115200 but the following word appears in the console section:
ets Jun 8 2016 00:22:57
rst: 0x1 (POWERON_RESET), boot: 0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP: 0xee
clk_drv: 0x00, q_drv: 0x00, d_drv: 0x00, cs0_drv: 0x00, hd_drv: 0x00, wp_drv: 0x00
mode: DIO, clock div: 1
load: 0x3fff0018, len: 4
load: 0x3fff001c, len: 928
I have 0 tail 12 room 4
load: 0x40078000, len: 8424
load: 0x40080400, len: 5868
entry 0x4008069c
**** Connected to COM5 @ 115200 baud ****
setup: rxfifo size before interrupt = 1
if I try to launch a command it tells me grbl has not finished booting .
if I do the same procedure without turning on the power of the cnc it appears to me the following message to infinity
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:928
ho 0 tail 12 room 4
load:0x40078000,len:8424
ho 0 tail 12 room 4
load:0x40080400,len:5868
entry 0x4008069c
ho 0 tail 12 room 4
ho 0 tail 12 room 4
entry 0x4008069c
what am I doing wrong?
thanks.
I can't connect my rs cnc with universal gcode sender.
Re: I can't connect my rs cnc with universal gcode sender.
Did you try in your tft mill -> usb option ... Works for me this way
Sent from my SM-A750FN using Tapatalk
A direct connection between your pc and GRBL exist only when you have selected on the tft the menu MILL and then USB
Hi! I am also having this problem. Even after the tft mill -> usb option. I've tried on two different PCs as well. Any help would be greatly appreciated!
I got it working, sort of. Once I set it to usb mode I have to reset the esp32. Then it works.
I expect you mean "reset the STM32 (GRBL)" instead of "reset the esp32".
You can do the reset/unlock before pressing mill->USB. The principle is that GRBL must be "IDLE"
Correct, STM32, not esp32, sorry about that.
Even with GRBL reporting IDLE (per the screen, top right), unless I press the reset button on my STM32 after pressing mill->USB and then hitting the connect button in Universal GCode Sender, it will always report as offline, and will report " grbl has not finished booting" for almost any action. Pressing the reset button on the STM32 at this point will always fix it. It's like there's a message that only gets sent at STM32 boot that Universal GCode Sender is looking for.
At reset GRBL sent a message saying GRBL and the version.
It could be that the PC program si waiting for this message.
The same message is sent by GRBL in reply to a "soft request" requested by the PC.
I had expected that the PC program sent such a "soft reset" when it tries to establish the connection.
