Problems with Y stepper
holyhax
Message par holyhax »
Hello Guys,
some friend of me, and I build the RS I3 1 year ago. Badly both of use have a Problem That our Print had go wrong like the Tower Of Pisa. We had a crooked layer at the Y Axis.
how faster the Print, it will be more worse. I Think we had Problem with loose steps but why? The Voltage at board we had tryed as well.
Does anybody had an Idea?
Thanks a lot
regards Mario
reis
Re: Problems with Y stepper
Message par reis »
I had the same issue
Check the belts even on x axe and tight them good.
vita.dosek
Message par vita.dosek »
I have the same problem with my Y axis, all the prints lean forward. I tried increasing voltage for stepper motors, tightening of belts and tightening of pulley screw, printing at low speed but nothing helped. Im running out of ideas... Have you figured it out? Could you please help me? Or do you have an idea what might be the issue?
Thank you,
Víťa
Terrible45
Message par Terrible45 »
maybe the mother card, we have a similar problem and 2 possibilty, if you can change the card or look HERE or a alternative solution HERE
