Mainboard Question
Spucky
Mainboard Question
Message par Spucky »
Hey friends!
I‘m new here, located in austria near the hungarian border. I‘m using an Anycubic i3 mega about 3 month‘s, and now i want to build the i3 RS.
I have only one question at the time.
I need the printer as silent as possible..
Is it possible to use the MKS GEN-L with TMC2208 instead of the base 1.6?
Can I use the firmeware with this board?
I would need a bigger case for the electronics, i know.. but that shouldn‘t be the problem.
kind regards
Christoph
Re: Mainboard Question
Hi Christof,
Yes you can use a Gen-L instead of the base, the firmware should work.
You'll maybe have to do some minors changes.
You have to know that MKS base 1.6 drivers are very quiet ;) but if you want another board/drivers, you can !
Cheers
Romain
