Hi, thanks for the amazing design! I want to build the RS-CNC as well, but I'm wondering how big i can build it before it loses stability. I want to mill sheets of foam with size 1 by 1 meter, about 15cm high. Is it possible to make a RS-CNC that big?
Thanks in advance!
Steyn
RS-CNC dimension
Re: RS-CNC dimension
Hi !
Yes of course you can increase the size of the CNC
If you wanna mill foam, you can make the CNC huge ! More than 1.5 meter without problem.
Romain
Romain
bonjour a tous ou trouvé le calculateur de coupe svp?, pour savoir à quel dimension coupé les profilé alu. j'aimerai qu'il coupe du 1500/1000 merci d'avance pour votre aide.
