I just finished to build my I3-RS printer, thanks for sharing it RoMaker!
My Y carriage is made out of MDF that I machined with a CNC, but I guess that the MDF plate I used
is warped, because my heated bed is uneven. First layers are not printed evenly.
I was thinking about purchaseing a Prusa i3 Y carriage, for example:
https://tehnologika.net/Prusa-i3-Alumin ... mm-Reprap/
Do you think it will match the I3-RS? My concern is about the linear rails, I'm not sure if they will match the distance from side to side.
Y Carriage Solution?
Re: Y Carriage Solution?
Hi, all sizes are good to mount on I3-RS
I'm interested to know what this material is they made that from. It sounds like a multilayer aluminum / plastic composite but I'm not familiar with that stuff. If you buy this plate, post up a pic of it - it looks very interesting !
Thanks
Lewis
Thanks
Lewis
[/quote]
Like you, I'm not quite sure what's the material they're using, so I preferred to buy it from a seller that uses 100% aluminium. It was also cheaper.
Another reason is that the holes for mounting the heated bed to the Y carriage are 4mm holes and I don't like it. On Aliexpress they're 3.5mm.
Hope it helps.
Thanks I checked the DXF file of your plates and the measurements pretty much match the ones of Prusa.
Hey Lewis, I ended up purchasing an aluminum plate from Aliexpress.
Hope it helps.
ok - sounds good ! I am planning to get my Y carriage and frame parts waterjet cut locally where a guy I know works, so it's not critical info, but I am curious about these laminated sheet products as I have seen them around and could not find much info on them.
Lewis
Lewis
