I had the problem that an old laptop unning Windows XP would not connect to the Arduino Mega board to run Repetier Host. None on the Arduino drivers would work and I could not to connect, no matter what I tried
After many hours of searching the Internet I found the solution from this guy on UTube
It appears that many of the Arduinos dont now use FTDI USB chips but CH340 USB chips. This guy has provided a link to download the driver for the CH340 which although in Chinese, works fine. After running the execuatable file it loaded the driver and I could connect to it without a problem.
I just thought I'd post this incase anyone else runs into this problem.
USB 2.0 driver solution
Retourner vers « GRBL32bits V1.0/1.5 »
Aller à
- ↳ Imprimante 3D "I3 RS"
- ↳ Mécanique I3 RS
- ↳ Câblage I3 RS
- ↳ Réglages I3 RS
- ↳ Imprimante 3D "I3-R"
- ↳ Mécanique I3-R
- ↳ Electronique de la "I3-R"
- ↳ Réglages et paramètres de la I3-R
- ↳ R-CNC
- ↳ Montage R-CNC
- ↳ Electronique R-CNC
- ↳ Réglages R-CNC
- ↳ Câblage RS-CNC (pas 32bits)
- ↳ Software RS-CNC (pas 32bits)
- ↳ Mécanique RS-CNC32
- ↳ Mécanique RS-CNC / RS-CNC32
- ↳ Câblage
- ↳ Réglages/flashage/utilisation
- ↳ Questions générales CNC
- ↳ Fraises et réglages usinages
- ↳ Logiciels CAO ET CAM
- ↳ Vos réalisations
- ↳ Vos imprimantes 3D
- ↳ Vos fraiseuses CNC
- ↳ Divers
- ↳ Vos objet imprimés et fraisés
- ↳ Présentations
- ↳ Bistro
- ↳ GRBL32bits V1.0/1.5
- ↳ I3 RS 3D printer
- ↳ R-CNC
- ↳ R-CNC Assembly
- ↳ R-CNC electronic
- ↳ R-CNC Adjustments
- ↳ I3-R 3D printer
- ↳ I3-R assembly
- ↳ I3-R Wiring
- ↳ I3-R Software
