Fredericton Makerspace Building The I3-RS
Re: Fredericton Makerspace Building The I3-RS
Romain -
I am digging around in the Marlin code you prepared for the I3-RS and I think I may have ordered the wrong Z axis screws. I see you have a steps/mm setting of 400 on the Z axis. This looks to be based on a screw with a lead of 8mm. (200*16)/8. BUT - I mistakenly ordered the 8mm screws with a single start and 2mm pitch - this means a lead of only 2mm and my steps/mm would be 1600 as a result.
I know that the setting can be changed in Marlin - however I am concerned that I will then have to "play" with the acceleration and jerk settings for the Z axis and for me that would be "rolling the dice" with no experience - haha.
Can you advise me on these extra settings for acceleration and jerk for the Z axis? The screws only cost me 11 dollars so I can always order the originally specified ones but I thought I would ask the master about this first (you)
Cheers from sunny Canada,
Lewis
Lewis
Hi Lewis,
For a leadscrew, there is 3 specifications:
-Diameter
-Pitch (distance between two slots)
-Lead (distance that moves the nut when you do a 360° turn with your leadscrew)
You can get a leadscrew 8mm diameter, 2mm pitch and a lead of 8mm ( what we need for I3-RS and what is the most common)
Can you show me the link of your leadscrew ?
-Diameter
Here's the link - I am pretty sure this is a lead of only 2mm as it's a single start screw with 2mm pitch,
https://www.banggood.com/8mm-T8x2-15020 ... rehouse=CN
Lewis
Lewis
RoMaker a écrit : ↑08 déc. 2018 11:31 Hi Lewis,
-Diameter
I think the lead is 8mm, as i said to you, it's the most common size, that would be mentionned if that was 2mm lead. All T8 leadscrews are made with 2mm pitch:
-2mm lead, there is just one thread of 2mm pitch
-4mm lead, there is 2 threads 2mm pitch
-6mm lead, there is 3 threads 2mm pitch
-8mm lead, there is 4 threads 2mm pitch
And if you get a 2mm lead, you just have to change Z value in Marlin
Yes, I think I will just wait until the screws I ordered have arrived - then I will know for sure.
On another note - I was reluctant to do anything with the heatbed until I had determined if Aliexpress seller wanted me to ship it back but it seems they do not want it and have just resent me a new one. So I took some acetone and wiped away the black paint that was covering the damaged trace. Surprise ! The trace itself was not damaged as suspected by one commentor. There was a shiny patch of copper under the paint. I will be able to use this heat bed as a backup - or for the second I3-RS that I may build
Here's a not too good picture of the result....
Good ! you won a free bed
I visited a friend of mine yesterday and we started making the 3d printed parts for my I3-RS ! Here's a pic of the results - I'm also making sure that I am abiding by the strict color code of Romain with neon green ABS
More parts are now finally arriving from China
I'll be posting again here soon with pictures of parts and progress as we start to assemble I hope.
Hope everyone is having a nice holiday season ,
Lewis
Lewis
My MKS Base V1.6 and TFT32 have arrived !
I have a question - I know that I can flash the I3-RS Marlin by only connecting the USB cable from the MKS board to my computer, but will it be possible to flash the new I3-RS firmware to the TFT32 with only the USB cable supplying the power to the MKS board and the TFT32 connected to the MKS board ?
i.e. - powering up the MKS V1.6 and the TFT32 with just the USB cable ?
Thanks
Lewis
Thanks
Lewis
hi
you can powering the mks and the tft with the usb cable but without power suply you can't uploading on the mks for the tft i don't know
Make Tomorrow Better
