SD card not loading
octa
SD card not loading
Message par octa »
Hi everyone;
I have just finished building my R-CNC. It is increible how easy this machine can be assembled.
right now I'm have some troubles with my smart LCD reading my SD card.
what ever i try it seam is doing nothing.
I have tryed the following.
-chaging the SD card format
-using an old 2 GB card
- reloading Marling several times
- sending M21 comand from REPETIER HOST
please let me know if some one had the same issue.
Regards
Octavio
Re: SD card not loading
Hi Octavio,
Is your problem that you can not start the job from the SD card or the Sd card is not recognized by the LCD? Can you give us more details please ?
Romain
thorkel
Message par thorkel »
Hi, same problem as described before, on the screen it prompts sd card connected, but when you go thru the menu prompts NO TF CARD. If you try to initialize it, nothing happens, and still the same after several re-uploads of software and a full hardware replacemente (Ramps, Arduino Mega and LCD module.
I feel like NEVER will finish my old R-CNC which i start building 3 years ago.
invertbob
Message par invertbob »
I'm currently having the same issues. 8, 16 & 32gig cards show "card inserted" ok but i can't access the card for files to machine? Been building this machine for the last 3 years and so close to finishing but stuck at final hurdle! :(
Cheers
Tommy.
