Software solution etc.
Dregild
Re: Software solution etc.
Message par Dregild »
Furthermore:
When I turn on the RS-CNC and try to use the Nunchucks it does not move in the correct directions - have to do a reset, before it behaves!
When I have used the Nunchuck to move the CNC I sometimes cannot move it with the TFT
Hi Drelig,
Have you tested with another Nunchuck ? Or verify that you don't have a wrong contact on the plug ?
We can not move the axis by TFT after moving by Nunchuck, it's a known bug, and we don't understand why for the moment, we are finding a solution, it's because firmware is still in beta version.
Dregild
Hi Romaker
Have You read my previous post about the new TFT (23.October 15.30)?
No problem with the contact on the Nunchuck. I will see if I can get hold of an original Nunchuck and see if that will work.
Thanks from Dregild
Steve H
Message par Steve H »
Now, I’m up an running I’m having very similar problems. The axis all work but the control from the Nunchuk is rather random, and often in one direction. Once I have tried the Nunchuk the TFT doesn’t allow any movements.
Is it best to wait until you’ve had chance to look at the firmware or is it worth loading a previous version as I can see for some people that seem to work.
Many thanks
