I3-RS with dual Z braces
André
Message par André »
I had a lot of problems with bed auto level one side of my first layer is stick on the heated but the other side its a bit height. And note that only one Z-brace (Z-reinforcement) cause a twist in my X axis, and a disfunction on BAL (bed auto level) so I decided remix the Z-reinforcement to avoid this problem. The files are at:
https://www.thingiverse.com/thing:3053512
Re: I3-RS with dual Z braces
Hi André !
have you mounted the power supply like the tutorial ? Because the power supply does the same effect that the Z brace of the other side.
André
Message par André »
Hi, Romain! I follow all instructions as described but my extruder its an MK8, maybe my extruder mount cause this twist and the only way to correct BAL was add a second Z brace.
