I have looked at the RS-CNC assembly section and must say congratulations for the excellent tutorial! It's really clear and understandable.
Now my idea is to use aluminium instead of mdf for the bed. A 12mm plate to be drilled and tapped, maybe with steel inserts. Any problems with that? Can I otherwise follow the instructions and be ok?
Aluminium bed
Re: Aluminium bed
Absolutely, you can install an aluminium bed and follow the tutorial.
Please send me a picture when your installation will be finished to see that
Re: Aluminium bed
Hello Romain,
Thanks for the feedback!
I will make sure to take a picture . So far I'm still printing parts and looking forward to start building it soon.
Re: Aluminium bed
one more question. What's best to use for the steel tubes? 1,5mm or 2mm wall thickness? I was about to order the latter, but thought it could be ineffective weight added to the carriage
Re: Aluminium bed
Hi !
It would seem that only the external size matters for the rigidity, for me there is no difference that you take 1.5 or 2mm wall thickness
Re: Aluminium bed
Hello Romain,
thanks for your feedback!
Another thing: What is your recommendation for using nylon nuts? Is it optional or in what places does it make sense?
Re: Aluminium bed
If you have the choice, you can install M6 nylon nuts everywhere (or loctite thead lock), it's safer because of vibrations.
