Maybe someone has found cheap collet adapter for metric bits? I'm still waiting for my bits with 3.175 size to come from China, so I thought about buying one or two from local shop. And everything they have for wood are bit's with 8mm width. They also have 6mm which I suppose would fit into 1/4" collet, but those 6mm bits are too expensive
Another question - if I would by collet for makita router, will it fit?
Metric collet adapters for Katsu
Re: Metric collet adapters for Katsu
Hi !
Yes, the Katsu is a Makita clone, wich the parts are compatible with each other
