milling speed and trevel speed
fullspeed1236
Message par fullspeed1236 »
Hello
I have problem.I testing speed of milling at 500 mm/min. if I do mill rectagle 25x25 cm i get 2 minute and that is 500mm/ min. If I do mill only drill on each corner (4 drill) my R-CNC move between this 4 drill with about half of speed and "milling" last about 4 or more minutes. I using ESTLCAM.. Can anybody tell me where I have wrong settings, I want "empty" spreed equal like I milling.
BR
Sebastjan
Re: milling speed and trevel speed
Hi Sebastjan,
if I understand correctly you want to increase the speed of empty movement?
In Estlcam >"Setup" tab (next to Workspace) -> "CNC program generation" tab -> "Values" tab
In the box "Rapid feed" I put 2400
fullspeed1236
Hmm.. I dont find that settings (estlcam 11).. It is strange.. feedrate is 500 and OK when milling. When go "empty" to next to drill hole go very slow..
BR
Sebastjan
fullspeed1236
Thanks ... I will try this settings.
BR
Sebastjan
fullspeed1236
Hello
RoMaker very thanks for sugestion. Speed is now OK.. Happy :)
Terrible45
Message par Terrible45 »
Romaker is a best ;)
