finnaly my R-CNC work fine.. But I want endstops and for sure I wiring on 2 wrong pin (+-). now my LCD is dead and nothong work.. question... wich board is faulty?..
BR
Sebastjan
dead ramps 1.4 ?
Re: dead ramps 1.4 ?
Hello Sebastjan !
You have wired the endstop between + and - ? If it's the case you do a short circuit
You should connect the endstop between - and S pin (signal)
Yes... shot citrcut.. I try and stop only in one direction, then I swich betven + and - and dead.. Wich board is now faulty? uper one or mega 2560?
it's hard to say but I think the mega 2560 5v regulator burned
Hi Sabastjanfullspeed1236 a écrit :finnaly my R-CNC work fine.. But I want endstops and for sure I wiring on 2 wrong pin (+-). now my LCD is dead and nothong work.. question... wich board is faulty?..
BR
Sebastjan
Hope you dont mind me contacting you but did you manage to get the endstops sorted and if you did can i ask :=
1 what type of endstops did you use
2 where did you place them
3 where did you finally wire them too and did you need any extra software.
Thanks in advance.
Tony
Sent from my iPad using Tapatalk
