Problems
Grzegorz
Problems
Message par Grzegorz »
Hi,
I have some problems.
R-CNC is almost completed but I'm experiencing some troubles. I'm converting *dxf file in Estlcam and when I'm starting program the machine starts the code but than the electronics (Ramps) is restarting by itself :(
I don't know what to do. Maybe somebody can help me? Please.
Sometimes it is going ok with the square (for example) but sometimes restarting. When I'm trying to "cut" circle machine is doing strange things I mean everything instead a circle :(
I'm not cutting yet it's only "dry" run without spindle running etc.
When I'm moving axes by software, all working fine.
Where can be a problem?
Thanks in advanced
Grzegorz
Re: Problems
-try a job with repetier host, and put the logs 'on' to see if it's you can 'read' the problem
-If you can, try to touch the 3 drivers and the Mega+Ramps to see if it's not too hot. Put a strong fan if needed.
-if you're using USB, use the short blue one.
-if it's a chinese Mega, you can have trouble just because of that
Grzegorz
Re: Problems
Thanks Aze,
The drivers tb6600 and ramps&arduino are cold not even little bit warm.
Tomorrow I will try short USB cable and log in RepetierHost.
Mega......it's 99,9% Chinese .
I had changed the threaded rod but still the same. :roll:
Re: Problems
Check if the 99.9% is well welded. Very often, the green part is crap. Otherwise, do you have any problems with the power supply (your ledstrip is constant or not)?
Grzegorz
Re: Problems
This is the LOG
It's reseting always when moving X
[quote]16:55:40.750 : N29 M105*28
16:55:43.796 : N30 M105*20
16:55:46.859 : N31 M105*21
16:55:49.921 : N32 M105*22
16:55:52.984 : N33 M105*23
16:55:56.343 : Preferred name from C:\Documents and Settings\mh1\Pulpit\kwadrat2.gcode to kwadrat2
16:55:56.421 : N34 M105*16
16:55:59.437 : N35 M105*17
16:56:02.500 : N36 M105*18
16:56:05.328 : N37 G90*36
16:56:05.328 : N38 M3 S24000*94
16:56:05.328 : N39 G0 Z5*92
16:56:05.328 : N40 G0 X1.5 Y1.5*28
16:56:05.328 : N41 G0 Z0.5*77
16:56:05.328 : N42 G1 Z-1 F600 S24000*109
16:56:05.343 : N43 G1 Y98.5 F1200*25
16:56:05.343 : N44 G1 X98.5*122
16:56:05.343 : N45 M117 ETE 38s*57
16:56:05.343 : N46 G1 Y1.5*73
16:56:05.343 : N47 G1 X1.5*73
16:56:05.343 : N48 G0 Z5*90
16:56:05.359 : N49 G0 X1.5 Y4.6556 Z5*106
16:56:05.359 : N50 G0 Z0.5*77
16:56:05.375 : N51 G1 Z0 F600*6
16:56:05.375 : N52 G1 Y98.5 F1200*25
16:56:05.375 : N53 G1 X98.5*124
16:56:05.375 : N54 G1 Y1.5*74
16:56:05.375 : N55 G1 X1.5*74
16:56:05.375 : N56 G1 Y4.6556*120
16:56:05.390 : N57 G0 Z5*84
16:56:05.390 : N58 G0 X0 Y0*21
16:56:05.390 : N59 M5*26
16:56:05.453 : Drukowanie zakoŮczone o 2017-08-14 16:56
16:56:05.453 : Czas drukowania:0s
16:56:05.453 : Wys≥ane linie:23
16:56:05.468 : N60 M30*38
16:56:05.500 : N61 M104 S0 T0*22
16:56:05.500 : N62 M140 S0*81
16:56:06.468 : N63 M84*42
16:56:06.828 : N64 M105*21
16:56:08.046 : Deletion failed, File: .ok
16:56:08.625 : N65 M105*20
16:56:11.687 : N66 M105*23
16:56:14.750 : N67 M105*22
16:56:17.828 : N68 M105*25
16:56:19.062 : Printer reset detected - initalizing
16:56:19.062 : start
16:56:19.062 : echo:Marlin 1.1.0-RC7
16:56:19.062 : echo: Last Updated: 2016-07-31 12:00 | Author: (none, default config)
16:56:19.062 : Compiled: Aug 12 2017
16:56:19.062 : echo: Free Memory: 3245 PlannerBufferBytes: 1232
16:56:19.062 : echo:Hardcoded Default Settings Loaded
16:56:19.062 : echo:Steps per unit:
16:56:19.062 : echo: M92 X2560.00 Y240.00 Z2560.00 E200.00
16:56:19.062 : echo:Maximum feedrates (mm/s):
16:56:19.062 : echo: M203 X15.00 Y180.00 Z6.00 E25.00
16:56:19.078 : echo:Maximum Acceleration (mm/s2):
16:56:19.078 : echo: M201 X50 Y50 Z20 E10000
16:56:19.078 : echo:Accelerations: P=printing, R=retract and T=travel
16:56:19.078 : echo: M204 P50.00 R3000.00 T50.00
16:56:19.093 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
16:56:19.093 : echo: M205 S0.00 T0.00 B20000 X4.00 Z0.40 E5.00
16:56:19.093 : echo:Home offset (mm)
16:56:19.093 : echo: M206 X0.00 Y0.00 Z0.00
16:56:19.093 : echo:Material heatup parameters:
16:56:19.093 : echo: M145 S0 H190 B50 F0
16:56:19.093 : echo: M145 S1 H240 B110 F0
16:56:19.093 : echo:PID settings:
16:56:19.093 : echo: M301 P17.98 I0.98 D83.62
16:56:19.093 : echo:Filament settings: Disabled
16:56:19.093 : echo: M200 D3.00
16:56:19.093 : echo: M200 D0
16:56:19.234 : N1 M110*34
16:56:19.234 : N2 M115*36
16:56:19.234 : N3 M105*36
16:56:19.234 : N4 M114*35
16:56:19.234 : N5 M111 S6*98
16:56:19.234 : N6 T0*60
16:56:19.234 : N7 M20*22
16:56:19.234 : N8 M80*19
16:56:20.875 : N9 M105*46
16:56:23.937 : N10 M105*22
16:56:24.671 : N11 M20*33
16:56:24.687 : echo:SD card ok
16:56:24.750 : FIRMWARE_NAME:Marlin 1.1.0-RC7 (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:GERUS R-CNC EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
16:56:24.750 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0 Y:0 Z:0
16:56:24.750 : echo:DEBUG:INFO,ERRORS
16:56:24.750 : echo:Active Extruder: 0
16:56:24.750 : Begin file list
16:56:24.750 : N12 M220 S100*82
16:56:24.750 : N13 M221 S100*82
16:56:24.750 : N14 M111 S6*82
16:56:24.750 : N15 T0*14
16:56:24.765 : /TRASHE~1/501/BOTTOM~1.GCO
16:56:24.765 : /TRASHE~1/501/Y-BELT~1.GCO
16:56:24.765 : /TRASHE~1/501/H_Y-DO~1.GCO
16:56:24.781 : /TRASHE~1/501/H_J-MA~1.GCO
16:56:24.781 : /TRASHE~1/501/H_J-MA~2.GCO
16:56:24.781 : /TRASHE~1/501/H_CLAM~1.GCO
16:56:24.781 : /TRASHE~1/501/H_CLAM~2.GCO
16:56:24.781 : /TRASHE~1/501/H_2014~1.GCO
16:56:24.781 : /TRASHE~1/501/H_POKR~1.GCO
16:56:24.796 : /TRASHE~1/501/H_JOIN~1.GCO
16:56:24.796 : /TRASHE~1/501/H_POKR~2.GCO
16:56:24.796 : /TRASHE~1/501/H_VISE~1.GCO
16:56:24.796 : /TRASHE~1/501/H_VISE~2.GCO
16:56:24.796 : /TRASHE~1/501/H_VISE~3.GCO
16:56:24.796 : /TRASHE~1/501/H_VISE~4.GCO
16:56:24.796 : /TRASHE~1/501/H_VISE~5.GCO
16:56:24.796 : /TRASHE~1/501/H_VI~107.GCO
16:56:24.796 : /TRASHE~1/501/H_VI~111.GCO
16:56:24.812 : /TRASHE~1/501/FRAME_~1.GCO
16:56:24.812 : /TRASHE~1/501/TOMAKZ~1.GCO
16:56:24.812 : /TRASHE~1/501/H_FRAM~1.GCO
16:56:24.812 : /TRASHE~1/501/WINDIN~1.GCO
16:56:25.234 : KWADRA~2.GCO
16:56:25.312 : End file list
16:56:25.390 : Begin file list
16:56:25.406 : /TRASHE~1/501/BOTTOM~1.GCO
16:56:25.406 : /TRASHE~1/501/Y-BELT~1.GCO
16:56:25.406 : /TRASHE~1/501/H_Y-DO~1.GCO
16:56:25.406 : /TRASHE~1/501/H_J-MA~1.GCO
16:56:25.406 : /TRASHE~1/501/H_J-MA~2.GCO
16:56:25.421 : /TRASHE~1/501/H_CLAM~1.GCO
16:56:25.421 : /TRASHE~1/501/H_CLAM~2.GCO
16:56:25.421 : /TRASHE~1/501/H_2014~1.GCO
16:56:25.421 : /TRASHE~1/501/H_POKR~1.GCO
16:56:25.421 : /TRASHE~1/501/H_JOIN~1.GCO
16:56:25.421 : /TRASHE~1/501/H_POKR~2.GCO
16:56:25.421 : /TRASHE~1/501/H_VISE~1.GCO
16:56:25.421 : /TRASHE~1/501/H_VISE~2.GCO
16:56:25.437 : /TRASHE~1/501/H_VISE~3.GCO
16:56:25.437 : /TRASHE~1/501/H_VISE~4.GCO
16:56:25.437 : /TRASHE~1/501/H_VISE~5.GCO
16:56:25.437 : /TRASHE~1/501/H_VI~107.GCO
16:56:25.437 : /TRASHE~1/501/H_VI~111.GCO
16:56:25.437 : /TRASHE~1/501/FRAME_~1.GCO
16:56:25.437 : /TRASHE~1/501/TOMAKZ~1.GCO
16:56:25.437 : /TRASHE~1/501/H_FRAM~1.GCO
16:56:25.437 : /TRASHE~1/501/WINDIN~1.GCO
16:56:25.875 : KWADRA~2.GCO
16:56:25.953 : End file list
16:56:26.015 : echo:DEBUG:INFO,ERRORS
16:56:26.015 : echo:Active Extruder: 0
16:56:27.000 : N16 M105*16
16:56:30.062 : N17 M105*17
16:56:33.125 : N18 M105*30
/quote]
Re: Problems
At least, you know where the problem comes from.
You can try that:
-Change the X driver with the Y one. Test again.
-Try to lower some X values (for example max_feedrate: 10, max_acceleration: 25, default_acceleration: 25, default_travel_acceleration: 25, default_XY_jerk: 2.5) and test if it's working. (in configuration.h in Marlin)
-Check (again!) if your X driver is correctly set to 16microsteps and with the correct voltage.
-Check the EEPROM values in Repetier Host (they must be the same as Marlin, otherwise reset the values in Repetier to have the same values).
I hope you will find your problem soon.
Grzegorz
Re: Problems
Aze I own you a big, big , big box of beer!!!!! :mrgreen:
It's alive.
Thanks again for your help.
I hope it's over (problems)
Re: Problems
You're welcome. Let me guess: the 16 microsteps on the driver was the problem?
Grzegorz
Re: Problems
No. the settings in Marlin.
Anyway I don't understand why when it's drawing (I am using a pen ) X is going slower than Y?
Should I change something with speeds?
Sorry! My knowledge about electronics is below "zero".
But I'm learning.
Thanks again.
Whenever are you in Poland give me a shout. I own you this :)
Grzegorz
Re: Problems
