I modified the two drilling templates for X and Z axis parts. Since I am most used to it, I used Sketchup.
Due to restrictions in this board, this post contains just the Z files.
In both templates I did the following:
- added drilling diameter and tapping size within borders around same sizes, so all holes are labelled in-place
- put shallow plugs in the drilling holes with a very small hole, so you can use a center punch or similar to mark the positions
- since my 3d printer does not support the full 20cm needed, I made printable pdf files for paper output. Print the template, scale resolution
for correct measurements, reprint and stick the paper to the work piece.
Hope someone finds this useful
Modified milling templates Z
Re: Modified milling templates Z
Hi !
Thank you for your participation Ewald
