[SOLVED] Reset ESP32 TFT
Re: Reset ESP32 TFT
Thanks mate, the connection between the two boards is made like the assembly manual, i have just used shorter cables female to female, but non shielded. You think that might be the problem with the nunchuck? Before the update my nunchuck was working perfect. It seems to be the only problem at the moment because every time i power on the cnc a new one pops up
i forget to mention , two days before, my power supply burnt the chip ka7500, i replaced it and now works like charm. In fact, i power on the cnc, use the nunchuck to move my axis and after 4 sec of use system turns off and then i found the problem with the power supply. You think that might also the nunchuck burnt? i will search on how can i check the nunchuck if it is burnt or not and post again. Thank you for your time!
Re: Reset ESP32 TFT
Problems solved, the cover of the tft was pushing the contacts of the nunchuck as a result to not working the nunchuck, thanks for your help!
