I just updated to 1.5 (seems like I must have just missed ordering when 2.0 came out - next time). While updating, I also changed from TB6600 drivers to the DM556 stepper drivers. IT IS SO MUCH QUIETER NOW!
Couple things I'm hoping there is a way to change settings.
1) By default, my CNC comes locked. I liked being able to just pick up the nunchuck and start jogging. Also, if while jogging I hit and endstop, I get an error message and have no idea how to clear it. I usually have to power cycle.
2) The reset button no longer resets the work location. I did like that feature, but suppose I'll get used to the button in time.
3) I'm using a spindle. IF I hit the pause button, it stops everything, but on resume, the spindle never turns back on.
4) My Z step seems off. Switches are the same for all 3 axis' but the z step appears to be only about half of what it should be.
Thanks in advance if you know how to fix these items.
Just Upgraded
Retourner vers « GRBL32bits V1.0/1.5 »
Aller à
- ↳ Imprimante 3D "I3 RS"
- ↳ Mécanique I3 RS
- ↳ Câblage I3 RS
- ↳ Réglages I3 RS
- ↳ Imprimante 3D "I3-R"
- ↳ Mécanique I3-R
- ↳ Electronique de la "I3-R"
- ↳ Réglages et paramètres de la I3-R
- ↳ R-CNC
- ↳ Montage R-CNC
- ↳ Electronique R-CNC
- ↳ Réglages R-CNC
- ↳ Câblage RS-CNC (pas 32bits)
- ↳ Software RS-CNC (pas 32bits)
- ↳ Mécanique RS-CNC32
- ↳ Mécanique RS-CNC / RS-CNC32
- ↳ Câblage
- ↳ Réglages/flashage/utilisation
- ↳ Questions générales CNC
- ↳ Fraises et réglages usinages
- ↳ Logiciels CAO ET CAM
- ↳ Vos réalisations
- ↳ Vos imprimantes 3D
- ↳ Vos fraiseuses CNC
- ↳ Divers
- ↳ Vos objet imprimés et fraisés
- ↳ Présentations
- ↳ Bistro
- ↳ GRBL32bits V1.0/1.5
- ↳ I3 RS 3D printer
- ↳ R-CNC
- ↳ R-CNC Assembly
- ↳ R-CNC electronic
- ↳ R-CNC Adjustments
- ↳ I3-R 3D printer
- ↳ I3-R assembly
- ↳ I3-R Wiring
- ↳ I3-R Software
