does anyone of you connected successfully the CNC via USB with Estlcam?
Is it possible to control the CNC with Estlcam?
Connecting Estlcam to RS-CNC32?
Re: Connecting Estlcam to RS-CNC32?
Hi Kraut,
I changed to Estlcam.
But installed a simple Arduino Uno instead of the original elektronics. Very cheap and easy to do!
You find the installation pattern in Estlcam.
It works perfect! Installation takes a few seconds.
Imo Estlcam is a very good alternative for beginners. It takes about one hour and you are in it.
Greets Martin
Greets Martin
Thanks for you reply Martin!
OK nice.
So Estlcam connected to the origin hardware does not work?
It's a little bit sad if I change the hardware to Arduino I will loose the touch screen option.
Regards
Kraut
OK nice.
Regards
Kraut
