I took some picture before scrapping the unit, so I thought I’d share them with you, and possibly start a discussion. I cannot say whether this PSU has been built according to the required safety standards or not, but there are some telltale signs which point to the opposite. Here’s what I found:
- Dirty. Everything is covered in grime, dirt and production residue. Right off the bat this should be taken as a warning sign that something is not right. It's a good indicator that the manufacturer does not care about their products.
- Missing 110V-220V switch. Beware of this is you live in a 110V country. With the switch gone the PSU works in 220V mode only. (Note that the marking label states 110/220V - which it clearly is not).
- Missing mounting screws on circuit board. On my PSU the PSB were held in place with only 3 screws. Again, this is another telltale sign of poor workmanship and quality control. It makes you wonder what else they forgot to install.
- Bad installation of thermal pads. Again, another sign of poor workmanship. On my PSU the thermal pad was folded over, causing poor thermal contact with the aluminum heat spreader. Thermal goop was somewhat spread around randomly. Without proper cooling the life expectancy of those components is greatly reduced.
- Cold soldering, starved solder joints & too much solder. I don't think I've seen so many bad solder joints on a single PCB before. Whoever did this soldering job clearly had no understanding of how to solder properly. These bad soldering joint cause poor connections with increased resistance and will most likely fail prematurely.
- Inadequate marking label. In the EU (and US) there are certain requirements to the information listed on a marking label, such as manufacturer ID, model number, ratings and so on. In addition to this comes mandatory approvals and safety declarations. The minimum requirement for sales in the EU is a CE marking - which basically is a self-declared statement from the manufacturer saying that the product is in accordance which the required standards and regulations. Well, this label has no such CE marking - a telltale sign of a non-compliant PSU.
I'm not an expert on power supplies, but I have dabbled with electronics enough to recognize bad soldering. The PSU in question works just fine. It gives exactly 24V on the output with no apparent problems otherwise. I’m not saying this is a dangerous power supply, but still, based on what I've written above, I decided to be on the safe side and not use this particular PSU in my RS-CNC32. It has been replaced by a more expensive power supply of good brand and reputation instead.
