Laser problems
jodougie2812
Laser problems
Message par jodougie2812 »
Hello. I don't know if I'm in the correct place on this forum but I need help with the laser on my RCNC32
I've mounted at 15 watt laser and connected it to the board. Following the instructions on the firmware section.
The laser works but in the negative..
When I switch on it immediately lights up at full power.
Using LaserGRBL to burn a test diagram. The laser switches on and off but is on when it should be off..... and off when it should be on. Burning the background instead of the lines.
I hope that makes sense......
Is there a setting I need to change in GRBL. I have loaded the latest version of the firmware onto the card
Any help appreciated
Re: Laser problems
Hi jodougie2812,
Yes, you have to take a look in GRB where the PWM signal have to be inverted.
The only way to check and modify it, if necessary, is to flash again the STM-32. I updated the assembly manual for that.
Take a look at the submanual dedicated to the STM-32 programming à the end of the assembly manual (link in my sign).
Moreover, if you reflash the STM-32 with the last firmware of the STM-32 available on the mstrens' GitHub page, do not forget to activate the laser mode before reflashing or connecting to GRBL via USB (in this case the command to send to GRBL will be $32=1)
See ya,
jodougie2812
Re: Laser problems
Thanks. I will have a look.. im not sure how to invert the PWM . Hopefully it may become clear when I take a look tomorrow
Thanks
jodougie2812
Re: Laser problems
Hello again.
I've looked at the GRBL using Antonio and am completely confused.
Can you give me an idea as to what I should be looking for.
Where I should find it and
What I should change it to.
Any help is appreciated. I think my brain may be too old for this steep learning curve
Thanks
Re: Laser problems
In the config.h file from the STM32 you have those lines:
// added by MS in order to allow to invert the PWM signal
// uncomment to invert PWM signal (it is implemented only for STM32F103 board.
#define INVERT_SPINDLE_PWM
jodougie2812
Re: Laser problems
Wow this is difficult
I followed the instructions. Using Attolic True Studio.
I open config.h and remove the # from the #define INVERT_SPINDLE_PWM command
I then rebuild the project and it generates 2 errors
expected '=', ',', ';', 'asm' or '__attribute__' before 'uint8_t' in nuts_bolts.h and
unknown type name 'define' on line280
If i put the # back in front everything builds successfully.
Help please :)
Modifié en dernier par jodougie2812 le 22 févr. 2021 10:17, modifié 1 fois.
Re: Laser problems
In fact you do not have to remove the #.
When you have
then the signal is inverted
In order NOT to invert it, you must have (adding // in front)
//#define INVERT_SPINDLE_PWM
Depending on your laser you need the one or the other.
So try with one, and if the signal is inverted, try the other one
jodougie2812
Re: Laser problems
thanks i will give it a go
jodougie2812
Re: Laser problems
Thanks. That worked.
