Hello!
I have the problem that my CNC restarts at a certain point in the gcode. It does not happen with only one gcode but with multiple ones. Already I have searched for any faults in the codes, but I could not find any.
Does anyone have any idea why this could happen?
CNC restarts frequently
Re: CNC restarts frequently
I see 2 reasons:
- If there is some "noise" on the wire that connect TX from ESP32 to Rx from STM32, it could be that some characters are disformed and the STM32 get a character that is considered being a Soft Reset.
- The STM32 has a pin that is foreseen to force a soft reset of GRBL. If this pin is connected to a button using long unshielded wires, it could be that, due to "noise" on the wires, the STM32 get signal that is interpreted as a request for a reset. To check if this is the reason, disconnect the wires for the button from the shield and install a jumper.
Hi,
I've the same problem, usually when i first run the router (cheap chinese router), grbl restarts, sometimes when while router runing.
Seems that because of noise.
How can i prevent this?
Thanks,
Murat
Thanks,
Murat
Do you think it's code and not a weak connection between the TFT and the board? Feels like the design of the mounts and screen cover slightly interfere on my machine, if I wiggle the TFT/screen cover, the screen will blank out and stop milling.
