since yesterday my Z axis of the I3-r behaves very strange.
Whenever i want ot zero it it only moves upwards never down.
When i turn the spindels down by hand so the sensor turns on but as soon as i click on "home Z" in the Repetier host it first moves up a bit stops shortly and the continues up another 3 cm an stops.
The same happens withe PC disconnected and use the "auto home" form the printer panel.
I already repalced the Motor Driver but no change.
I deleted the Arduino and reflashed it from scrach - no change.
I disconnected and reconnected all cables on the Ramps Board to make sure no bad or loose contact - no change.
All other motors and funcitions work.
Can the Arduino itself have such a fault? Or the Ramps 1.4 Board?
Any advice welcome
Cheers Erwin
Z-Axis gone crazy
Retourner vers « I3-R Software »
Aller à
- ↳ Mécanique RS-CNC32
- ↳ Questions générales CNC
- ↳ Logiciels CAO ET CAM
- ↳ Vos réalisations
- ↳ Vos imprimantes 3D
- ↳ Vos fraiseuses CNC
- ↳ Divers
- ↳ Présentations
- ↳ Bistro
- ↳ Imprimante 3D "I3 RS"
- ↳ Mécanique I3 RS
- ↳ Câblage I3 RS
- ↳ Réglages I3 RS
- ↳ Imprimante 3D "I3-R"
- ↳ Mécanique I3-R
- ↳ Electronique de la "I3-R"
- ↳ R-CNC
- ↳ Montage R-CNC
- ↳ Electronique R-CNC
- ↳ Réglages R-CNC
- ↳ Câblage
- ↳ R-CNC
- ↳ R-CNC Assembly
- ↳ R-CNC electronic
- ↳ R-CNC Adjustments
- ↳ I3-R 3D printer
- ↳ I3-R assembly
- ↳ I3-R Wiring
- ↳ I3-R Software
- ↳ GRBL32bits V1.0/1.5
- ↳ I3 RS 3D printer
