Hi,
I noticed while milling some plywood (multiplex), a high pitched sound/vibration.
My makita 750W corded router at that point starts to go up/down in rpms because the dial wheel on the router starts to turn because of the vibrations.
Any idea how to prevent this from happening?
I usually mill setting the router dial wheel to 3, with 800mm/min feedrate.
Best regards,
Jan
Vibrations
Retourner vers « GRBL32bits V1.0/1.5 »
Aller à
- ↳ Imprimante 3D "I3 RS"
- ↳ Mécanique I3 RS
- ↳ Câblage I3 RS
- ↳ Réglages I3 RS
- ↳ Imprimante 3D "I3-R"
- ↳ Mécanique I3-R
- ↳ Electronique de la "I3-R"
- ↳ R-CNC
- ↳ Montage R-CNC
- ↳ Electronique R-CNC
- ↳ Réglages R-CNC
- ↳ Mécanique RS-CNC32
- ↳ Câblage
- ↳ Questions générales CNC
- ↳ Logiciels CAO ET CAM
- ↳ Vos réalisations
- ↳ Vos imprimantes 3D
- ↳ Vos fraiseuses CNC
- ↳ Divers
- ↳ Présentations
- ↳ Bistro
- ↳ GRBL32bits V1.0/1.5
- ↳ I3 RS 3D printer
- ↳ R-CNC
- ↳ R-CNC Assembly
- ↳ R-CNC electronic
- ↳ R-CNC Adjustments
- ↳ I3-R 3D printer
- ↳ I3-R assembly
- ↳ I3-R Wiring
- ↳ I3-R Software
