Hi,
Can anyone help on this. I managed to create a z probe button as described in the excellent instructions, but after completing the probe check the cancel button, or anything else won’t let me return to any other screen. Has anyone else found this?
Many thanks
Not returning from new buttons
Re: Not returning from new buttons
I would have to check.
Are you using the latest version of the firmware?
It is available here
https://github.com/mstrens/grbl_controller_esp32
Thanks for the quick reply. Yes, I am, but trying a bit more I can see I had some alarms and I hadn’t realised that I can touch “alarm” to show more. I think I need to look a little more at the cause of the alarm.mstrens a écrit :I would have to check.
Sent from my iPad using Tapatalk
I think I hadn’t gone through the calibration process for the probe properly. Is the anything written down on how to do that with the z probe? Many thanks
In case of: did you see in the Z-Probe Gcode that you have to stay not higher than 30mm above the probe-plate to make it works?
G38.2 Z-30 F100 ;
G38.2 Z-30 F100 ;
Thanks Aze, I had seen that but it’s a good point and could be the cause of the alarm. I just wondered if there was any instructions for the calibration under the tools menu
